17 years agosimple vhdl question
when "000" PRICE = "110010"; How do I code the above so that it reads when "000" the price is "110010"
17 years agoIt depends on where you want to do it. If "000" is the value of some signal - say some_signal and you have various options then use a case statement, e.g.:
case some_signal
when "000" =>
PRICE <= "110010";
when "111" =>
PRICE <= some other value;
when others =>
PRICE <= some default value;
end case; note that the case statement has to be within a process. You could do if then else: if some_signal = "000" then
PRICE <= "110010";
else
PRICE <= some value;
end if; If you don't want / have a process then you coule write it as a concurrent statement - i.e just on its own: PRICE <= "110010" when some_signal = "000" else "some default value";
