14 years agoSilly question about which PCIe slot the Stratix V GX FPGA Development Board can use
From the documentation for this boards it states it can fit in a x1, x4, and x8 PCIe slot (it doesn't mention a x16). A collegue called a sales rep about whether or not a x16 slot will work and he was told it must be a x8 slot.
I have a feeling that sales rep misunderstood (or my collegue did), but I want to make sure whether or not this board can fit and operate using a x16 slot. Thanks! Jason2 Replies
yes, should be fine in a x16 slot - thats what I put my arria2 dev board into (it only has x8)
I have mine plugged into a x16 slot and it works fine.
Actually, it looks like they're x16 connectors with x8 PCIe; http://www.onestopsystems.com/pcie_atx_bp.php Regardless, you should be fine. If you have issues detecting the board, try a soft-reset of your CPU. I forget whether this board meets the PCIe power-on timing requirement. I typically boot my host CPU, hit-ESC to stall it, download the FPGA via JTAG, and then allow the host boot to continue. Cheers, Dave
