17 years agosigned/unsigned multipliers
I can't seem to find a way to instantiate a multiplier that will dynamically select between signed and unsigned multiplication. This is on a Cyclone II, but applies to other parts as well. Read...
17 years agoIt is always true if we allow for correct width. The issue of 8 bit width representing numbers from 0~127 and -1 to -128 is separate.
The puzzle still stands: - => + should reverse + => - naturally hence for - => + subtract 1 then invert (by definition) but how come the same rule apply to both conversions as well. i.e. [invert add 1] in either case.
