17 years agosigned/unsigned multipliers
I can't seem to find a way to instantiate a multiplier that will dynamically select between signed and unsigned multiplication. This is on a Cyclone II, but applies to other parts as well. Read...
17 years ago --- Quote Start --- I - => + invert bits then add 1 ?? how come this correct --- Quote End --- Still true. The only problem may be in the most negative number, which does not have the equivalent positive number in two's complement. That is, for 8-bits we can represent from -128 to +127. So, -128 does not have its positive equivalent.
