17 years agosigned/unsigned multipliers
I can't seem to find a way to instantiate a multiplier that will dynamically select between signed and unsigned multiplication. This is on a Cyclone II, but applies to other parts as well. Read...
17 years ago --- Quote Start --- Thanks Tricky. It does really work. So in principle you are doing what altera never tell us....as usual. To use unsigned, given a signed input: 1) double extend input width using sign extension 2) truncate output to double inputwidth Very useful discussion. --- Quote End --- IMO, Tricky side stepped the real issue. I already pointed out that the lower bits would be identical, so obviously widening the input would "solve" the problem, at a quadratic cost!! You (Kaz) provided an actual useful workaround. I'm still working with support to get the original bug fixed. Tommy
