17 years agosigned/unsigned multipliers
I can't seem to find a way to instantiate a multiplier that will dynamically select between signed and unsigned multiplication. This is on a Cyclone II, but applies to other parts as well. Read...
17 years agoSo your method involves sign extending both 9 bit inputs to 18 bit? This means, you need four multiplier blocks instead of one, not a useful suggestion, to my opinion. I would rather use signed/unsigned inputs with altmult_add, as previously said.
P.S.: O.K., it's only two instead of one block, still a waste of resources.
