10 years agoSigned addition in Nios II
Hi all, I need to add two numbers in Nios II. For that i simply add two numbers in Nios II C program. I have assigned the maximum possible 32 bit positive value .i.e. 0x7FFFFFFF in both. Wha...
10 years agoThe result doesn't saturate but Nios overflows and set the overflow status.
AFAIK this is the normal behaviour on other microprocessors, too. I have worked with a few uP which could saturate the result instead of generating an overflow, but this was always an option you had to explicitly enable.
