15 years agoSignalTap issue with lpm_mult dataa bits
Hi, I am using the SignalTap to read values off of my design. When I probe the inputs to the lpm_mult, dataa and datab, I come across wrong values. My inputs are both 16-bits wide. However...
15 years agoHere is the .vhd for the lpm_mult megafunction I am using:
LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY lpm; USE lpm.all; ENTITY multlpm IS PORT ( clock : IN STD_LOGIC ; dataa : IN STD_LOGIC_VECTOR (15 DOWNTO 0); result : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ); END multlpm ; ARCHITECTURE SYN OF multlpm IS SIGNAL sub_wire0 : STD_LOGIC_VECTOR (31 DOWNTO 0); SIGNAL sub_wire1_bv : BIT_VECTOR (15 DOWNTO 0); SIGNAL sub_wire1 : STD_LOGIC_VECTOR (15 DOWNTO 0); COMPONENT lpm_mult GENERIC ( lpm_hint : STRING; lpm_pipeline : NATURAL; lpm_representation : STRING; lpm_type : STRING; lpm_widtha : NATURAL; lpm_widthb : NATURAL; lpm_widthp : NATURAL ); PORT ( clock : IN STD_LOGIC ; dataa : IN STD_LOGIC_VECTOR (15 DOWNTO 0); datab : IN STD_LOGIC_VECTOR (15 DOWNTO 0); result : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ); END COMPONENT; BEGIN sub_wire1_bv(15 DOWNTO 0) <= "0000000001100100"; sub_wire1 <= To_stdlogicvector(sub_wire1_bv); result <= sub_wire0(31 DOWNTO 0); lpm_mult_component : lpm_mult GENERIC MAP ( lpm_hint => "INPUT_B_IS_CONSTANT=YES,MAXIMIZE_SPEED=5", lpm_pipeline => 1, lpm_representation => "SIGNED", lpm_type => "LPM_MULT", lpm_widtha => 16, lpm_widthb => 16, lpm_widthp => 32 ) PORT MAP ( clock => clock, dataa => dataa, datab => sub_wire1, result => sub_wire0 ); END SYN;
