16 years ago
Signaltap II
Hi!
I have two doubts.
I have a proyect and I have created a *.stp file.
I haven't used trigers conditions.
The problem is that I want to see the captured dates continously in a 10ms time.
and the windows in signaltap II only show 128 samples.
I use a 40MHz clock.
¿what I have to do to capture in the same windows or same log 10ms????
and the second doubt is:
¿can I capture two signals in signaltab in a vector in order to use them later with matlab????
many thanks in advance for your help.
    Thanks for every one.
    I will use triger conditions and alt_signaltap_run command in matlab!
    tanks!!!!!
    I am trying to import signaltap data into MATLAB. Every time I try to import data I get following error in MATLAB:
    " ??? One or more output arguments not assigned during call to
    "alt_signaltap_run"."
    I have my quartus project saved with folder name "My_project" within th bin directory of quartus. My .stp file name is "half_adder". Therefore when I want to import data into MATLAB, I type following command in MATLAB
    x = alt_signaltap_run('c:\altera\11.0\quartus\My_project\half_adder.stp', 'auto_signaltap_0').
    But it opens the help about alt_signaltap_run function and returns me above mentioned error.
    Please help me
    Thank you
    You have 2 errors:
    1.
    --- Quote Start ---
    \My_proje ct
    --- Quote End ---
    <--- no space needed
    2. Second parameter must be either 'signed' or 'unsigned', not Signaltap instance name.
    Thank you very much Andrew.
    I have got one new problem with my project.
    When ever I enable signaltap file with my project and try to recompile it, I get following errors:
    Error: MGL_INTERNAL_ERROR: File C:/Users/a7t0r/Desktop/My_Project/db/mux_gpc.tdf cannot be created. CAUSE : The file cannot be created. The file already exists, and is write-protected, or there is not enough space.
    Error: Can't elaborate inferred hierarchy "sld_signaltap:auto_signaltap_0|sld_signaltap_impl:sld_signaltap_body|altdpram:\stp_non_zero_ram_gen:attribute_mem_gen:attribute_mem|lpm_mux:mux"
    If I disable the signaltap file and then try to compile my project then it works properly.
    I would really appreciate your help.
    Thank you
    Gill
