11 years agoSignalTap II Configuration issues
We're having a really hard time getting SignalTap to work properly. We often get an "Invalid JTAG configuration" message and a "Compile the design before continuing" error for no apparent reason, whe...
11 years agoIn some cases, I also observe similar issue with SignalTap especially when after a number of rounds of design edit and compilations. What I did is I remove the existing stp instance and then recreate a new one. You could also try the same to see if it works.
