13 years agosignal tap logic analyser problem!!! (STP)
anyone know is there any known issue in 12.1 and 12.1sp1 QII signal tap logic analyser? 1) First, when i click run analysis / autorun analysis, the signal tap keep remaining in "waiting for trigger" stage even i didn't sent any trigger signal 2) Without changing anything, i re-compile the design again. 3) Now, i click run analysis / autorun analysis again, and the signal tap is working! I diff the the 2 fitter db file and found that there is a lot of different and i suspect maybe this different routing and placement make the stp working in 2nd compilation. This make me very embarrassing because many times i need to re-compile the design for 2 times in order to make the stp working! Anyone can help? Thanks, fpga891 Reply
Seem like no other user experience my problem? :(
