16 years agosignal tap - question
I certainly have a lot of experience with Xilinx devices and tools, not so much with altera so would certainly appreciate any assistance. I was handed an a altera design, and told to port all my xili...
16 years agoThe error message says, that SignalTap can't be used with exported partitions.
The Quartus Software Handbook tells ins this regard: --- Quote Start --- You can use the Logic Analyzer Interface in any project that you can compile and program into an Altera device. You cannot export a lower-level project that uses the Logic Analyzer Interface in a bottom-up incremental compilation flow. You must disable the Logic Analyzer Interface feature and recompile the design before you export the design as a partition. --- Quote End ---
