12 years agosignal power estimation
Hello guys.. I'm trying to implement a block that evaluates the signal rms value along n samples. So, using the std definition one must do (x_k is a complex number so I have to take in acc...
12 years ago --- Quote Start --- Dear kaz It's ok. But what about working with 16 bits words ? If you add up 2^20 samples of 4 you will get 4*2^20 that needs more than 21 bits.. or not ? --- Quote End --- 4*2^20 requires 3 bits + 20 bits = 23 bits. in your case you have to multiply say 8 bits * 8bits => 16 bits +16bits => 17 bits + 20bits => 37 bits You can imagine that by cascading pairs of additions: sample1(17bits) + sample2(17 bits) needs 18 bits (res1) sample3(17bits) + sample4(17 bits) needs 18 bits (res2) res1(18bits) + res2(18 bits) needs 19 bits ... thus you imagine 20 cascaded stages of addition needed for 2^20 samples
