12 years ago
Shift registers can be dangerous!
(note: re-posted from my blog.
http://xiaoleicestustc.blogspot.sg/2013/10/shift-registers-can-be-dangerous.html
The photo mentioned in my original post is in the attachment)
During the last two days, I have been debugging an issue on FPGA, and found in the end that the root cause is a 4-bit shift register.
See the photo below, which I drew to illustrate. It is a shift right register, and there are inverters at D input of bit 3 and bit 2. These four bits will be reset to "0000", and becomes, at consecutive rising clock edges, "1100", then "1010", then "1001", and back to "0000", and repeats the pattern. Looks like a normal and safe design, right?
What went wrong on FPGA in my case was that, I observed that these four bits would be stuck at "1000" after my FPGA was running some FW code for about 20 mins. I still am not quite sure whether these four bits become "1000" due to having latched some glitches. But once they become "1000", they will stay there, for ever. You can do the logic yourself.
As a result of this stuck, one important clock signal in my hardware design would be gone, which in turn would cause the FW to hang at a particular FOR loop. (Of course I am now in hindsight. In fact it took my colleague David and me almost one working day of debugging to trace from the hang FW back to this shift register).
As I see from this incident, shift registers can be dangerous!
