15 years ago
Shift register with asynchronous parallel load : Latch warning
I am trying to instantiate a Shift Register with an asynchronous parallel Load.
My design works like a charm but there is a warning that makes me not comfortable with it.
Warning: Presettable and clearable registers converted to equivalent circuits with latches. Registers power-up to an undefined state, and DEVCLRn places the registers in an undefined state.
    Warning (13310): Register "tmp" is converted into an equivalent circuit using register "tmp~_emulated" and latch "tmp~latch"
My code is the following :
library ieee;
use ieee.std_logic_1164.all;
entity shift_reg is
port
    C, ALOAD : in std_logic :='0';
    D            : in std_logic_vector(15 downto 0):= (others =>'0');
    SO          : out std_logic:='0'
end shift_reg;
architecture archi of shift_reg is
signal tmp     : std_logic_vector(16 downto 0) REGISTER := "00000000000000000";
signal adata : std_logic_vector(16 downto 0) REGISTER := (others=>'0');
signal count : integer :=0;
begin
    process (C,ALOAD,adata) is
    begin
    if ALOAD='1' then
    tmp <=adata;
    elsif (C'event and C='1') then
        If Count<16 then
        tmp <= tmp(15 downto 0) & '0';
        end if;
    end if;
    end process;
    process(C, ALOAD)
    begin
    if (ALOAD = '1') then
    count <= 0;
    count <= count + 1;
    end if;
    end process;
adata <= '0' & D;
SO     <= tmp(16);
end archi;
My question is what should i do to prevent those latches mentionned in the Warning lines?
Are those latches caused by the 'if' statement case, when 'ALOAD' and 'C' are both inactive?
Thanks in advance.
    Ok thank you for your answers but at the end what is the solution for that issue, except using the altera megafunction, I can't do my own Parallel loadable shift register? can't I ?
