arno_va
3 years agoShared reconfiguration controller for 2 (separate) transceivers
For my design I'm using a Cyclone V FPGA with 3 transceivers. My design requires 2 separate (duplex) transceiver fiber links. To accomplish this I'm using 2 separate transceiver instances and I assum...
- 3 years ago
Hi Zying,
One small question. Is it correct that when I create 2 separate transceiver instances, I need a (single) reconfig-controller with the following settings: "Number of reconfig interfaces = 4" and "Optional interface grouping = 2,2" ?
Kind regards,
Arno
ZiYing_Intel
3 years agoHi arno_va,
Can you share your .qar file here? So that I can try debug the issue from my side.
zying
arno_va
3 years agoDear Zying,
Here's the qar-file you requested. Hopefully it helps in resolving the issue.
ps. the transceiver/reconfig ip instances are at the bottom of the top-level.
Cheers,
Arno
