Shared reconfiguration controller for 2 (separate) transceivers
- 3 years ago
Hi Zying,
One small question. Is it correct that when I create 2 separate transceiver instances, I need a (single) reconfig-controller with the following settings: "Number of reconfig interfaces = 4" and "Optional interface grouping = 2,2" ?
Kind regards,
Arno
Hi arno_va,
Can you share your .qar file here? So that I can try debug the issue from my side.
zying
- arno_va3 years ago
Dear Zying,
Here's the qar-file you requested. Hopefully it helps in resolving the issue.
ps. the transceiver/reconfig ip instances are at the bottom of the top-level.
Cheers,
Arno
Dear Zying,
Thanks for your reply. I will provide the .qar-file as soon as I'm back at work (tomorrow).
Just to clarify about what I'm trying to accomplish: I basically want to interface a single C5G board with 2 (fiber) transceivers to 2 other C5G boards (each with a single transceiver).
Kind regards,
Arno
