13 years agoSGDMA with pipeline bridge inside a Qsys subsystem
Hi I'm trying to get an SGDMA core to run inside a QSys subsystem which has its own sgdma desc memory. And the subsystem is connected to the outside system with nios using an avalon mm pipeli...
13 years agoFor those who read this later.
Just be careful about the source/destination addresses you give to the sgdma core. They have to be the ones marked as viewed by sgdma ip core in system.h The descriptor address I used was initialized as follows alt_sgdma_descriptor *transmit_descriptors = (alt_sgdma_descriptor *) SUBSYSTEM_1_SGDMA_DESC_BASE; // This is a memory inside the subsystem It works. Cheers ZubairLK
