15 years agoSGDMA data transfer question.
I did a memory transfer test from RAM to SDRAM using SGDMA, the speed test was evaluated using performance counter core, and it shows the transfer rate goes up to 370 MB/s with all content copied correctly, which is too good to be true! when i used the same code on RAM to SRAM, the transfer rate only goes up to 50MB/s !!! WHY? i thought SRAM should be faster than SDRAM? i was testing my code in DE2-115. Maybe the SRAM is slower than SDRAM in DE2-115 ?? PS: Both cases were running at 100MHz.(same clock speed with CPU) Rregards, Michael13 Replies
This kind of speed is possible with SDRAM if you are using bursts or consecutive accesses, which is usually the case when transferring from a DMA.
If you had random transfers, then asynchronous SRAM could become faster than SDRAM in some cases. - Altera_Forum
How about my SDRAM speed? is this even possible at 370MB/s ?? its probably having the same transfer rate as the RAM to RAM .
If that's asynchronous SRAM (i.e. not SSRAM) then you will not be able to read/write to the SRAM every clock cycle. Look at the SRAM datasheet timing to see what I mean.
