15 years agoSGDMA data transfer question.
Hi, I did a memory transfer test from RAM to SDRAM using SGDMA, the speed test was evaluated using performance counter core, and it shows the transfer rate goes up to 370 MB/s with all con...
15 years agoIf that's asynchronous SRAM (i.e. not SSRAM) then you will not be able to read/write to the SRAM every clock cycle. Look at the SRAM datasheet timing to see what I mean.
