15 years agoSGDMA data transfer question.
Hi, I did a memory transfer test from RAM to SDRAM using SGDMA, the speed test was evaluated using performance counter core, and it shows the transfer rate goes up to 370 MB/s with all con...
13 years agoI assume by BRAM you mean on-chip memory. On-chip RAM is both high speed and low latency so you can't find a more efficient memory-to-memory transfers speed using an FPGA than between two on-chip memories. For example if I moved 50000 words of data between two independent on-chip memories, and assuming the DMA is the only thing accesses them you can expect a transfer time of approximately:
2 cycles (on-chip RAM latency) + ~ 4 cycles (latency through the DMA) + 50000 With an SDRAM that equation becomes (assuming two SDRAMs are involved): 12+ cycles (SDRAM latency) + ~ 4 cycles (latency through the DMA) + (50000 * ~0.95 (SDRAM has addressing and low level command overhead)) So if you replace one of the on-chip memories with SDRAM, it's the SDRAM that will be the limiting factor.
