14 years agoSGDMA and Shared memory
Hello All, I'm trying to understand how can I share memory between a nios application and vhdl logic. I have a DE0 nano board which has an SDRAM I want to use. I can't use only on chip mem...
14 years agoThank you for your reply Socrates.
So if I understand correctly : - I write a module with an avalon master port which I can control from user logic. Actually, it's an user bus to avalon bridge. - I create an new Qsys design with a Nios 2 processor, an SDRAM controller, an SGDMA controller and the new component with its avalon master port. - I connect both master port from the nios and the bridge to the SGDMA controller and the output of the DMA to the SDRAM controller. And for the hardware, that's all. I place reset and execution vector from the nios in the SDRAM. I can place DMA request from the nios to the SDRAM. I can place DMA request from the user logic to the SDRAM. Avalon switch fabric will automaticaly arbitrate between all the DMA request ? Am I in the wright direction ? Thanks for your help.
