15 years ago
SG-DMA descriptor chain not working.
Hi everyone,
I'm doing SG-DMA for streaming data to LCD.
This is how I do,
SG-DMA memory-to-stream SOPC connection.
descriptor read and write-->DDR-SDRAM
read data -->DDR-SDRAM
created descriptor using malloc.
descriptor 0:
current descriptor pointer: descriptor[0]
next descriptor pointer: descriptor[1]
SOP(start of package) = 1
EOP(end of package) = 0
descriptor 1:
current descriptor pointer: descriptor[1]
next descriptor pointer: descriptor[0]
SOP(start of package) = 0
EOP(end of package) = 1
PARK MODE ENABLE
so this configuration should introduce a loop chain for the descriptor. However its not working unless i put the loop only inside 1 descriptor(current descriptor pointer: descriptor[0]
next descriptor pointer: descriptor[0]).
I just want to make the data stream continuous base on this 2 descriptor. Is it I lost something??
Thanks for any reply. :o
    additional info:
    DDR(150MHz) -> SG-DMA (100MHz) -> VSYNC DRIVER(100MHz)
    SGDMA send 32bits,RGB converter convert it to 24 bits per 1 cycle, and the sync driver covert the 24 bits and send 8 bits for 3 times.
    Additional info from my question:
    descriptor(0)
    current_descriptor : descriptor[0]
    next_descriptor : descriptor[1]
    descriptor(1)
    current_descriptor : descriptor[1]
    next_descriptor : descriptor[2]
    descriptor(2)
    current_descriptor : descriptor[2]
    *if I create descriptor above, the data keep looping sending descriptor(2),
    *if I change next_descriptor(2) like below to get a loop,
    descriptor(2)
    next_descriptor : descriptor[0]
    *this one will cause the sgdma stop sending continuous data stream.
    :confused:
