RHark
7 years agoSEU Detection Architecture
Is the internal circuitry that performs the SEU detection fixed-in-place? As in, is it a hard-wired logic block that is only every used for the SEU IP, or is it implemented using logic cells that have other uses as well?
1 Reply
- JohnT_Altera
HI, The EMR unloader is based on the Configuration block which is a hard block while the rest of the logic is built in FPGA core.
