14 years agoserious problems about FIFO simulation
I implemented altera FIFO in my design and passed the functional simulation in Altera-modelsim 6.5e.
But I failed in the timing simulation,both writing and reading FIFO behavior. On the basis of phenomenon,I concluded the reason: In the testbench where clk is generated,I implemented the writing FIFO behavior like this: always @(posedge clk)begin .... if(wrreq) fifo_data_in <= ***; end the data port is updated immediately,but in my design,it will delayed for the fitting results,so,probably,the setup or hold time failed! My question is:How can I compensate the delayed time,and simulate FIFO successfully??? Thank you for your help!No RepliesBe the first to reply
