11 years agoSerializing Avalon-ST over XCVR for FPGA-to-FPGA Transmission
I would like to know what options are available for serializing Avalon-ST video data over high-speed XCVR for tranmission between two FPGAs with lowest latency? I have a set of HD resolution video in...
11 years agoYou'll want to use a mode that incorporates the 8/10B encoder. This makes recovering bytes out of the serial data stream trivial, and supports mismatched data rates through the use of IDLE codes.
I have not used it, but I am pretty sure the SerialLite core is for light-weight chip-to-chip communications. Xilinx have a similar protocol called Aurora. I don't know how compatible these two protocols are. Perhaps someone who has used them can comment. You should "do the math" to determine what sort of bit-rate you require, what sort of lane rate you think your PCB can handle, and hence how many SERDES lanes you will need. Cheers, Dave
