17 years agoSerial Flash Loader with Multiple Configuration Files
I'm starting a new design and would appreciate any info on the best way to do the following. I'm using Quartus V8.1 free version with a EP3C25 and an EPCS configuration device on a custom board. I wa...
17 years agoIf you wanted to use the SFL, then you will need a JIC(JTAG Indirect Configuration) file.
You may use the "Convert programming Files" option in the Quartus II software to achieve this See http://www.altera.com/literature/hb/cfg/cfg_cf52007.pdf You can add sof data for the application and Factory images and hex data for the user data Hope this helps
