9 years ago
Sequencial protocol comunication
Hi dears, im new in this forum, and no so far with fpga knowledge.
But ok im trying to learn, i post an experiment i want to comunicate with external component that have:
16 bit address/command
reset signal
chip select signal
and ahother 2 bits this doesnt matter. That i do work and work well... but i think that i dont are in the correct way... i have the feeling that could be more easy or "efficient"
this is my principal verilog:
module video_controller (input clock ,input start  ,input  color_in, input  x, input  y, input  h, input  w,output reg  data,output reg  latches,output  finish,output  color_in_next, output reg rst);
reg  i_counter=0;
//                          cs_rd_wr_rs
localparam  StartCmd=4'b0101;
localparam  EndCmd=4'b1111;
localparam  StartIdx=4'b0100;
localparam  EndIdx=4'b1110;
reg  init = 1'b1;
always@(posedge clock && init)
begin
i_counter<=i_counter+1;
//if(i_counter>7000)i_counter<=0;
case (i_counter)
10 :rst=1'b0;
1000 :rst=1'b1;
1010 :latches=StartIdx;
1020 :data=8'h01;
1030 :latches=EndIdx;
2000 :latches=StartIdx;
2010 :data=8'h01;
2020 :latches=EndIdx;
3000 :latches=StartIdx;
3010 :data=8'h01;
3020 :latches=EndIdx;
4000 :latches=StartIdx;
4010 :data=8'he0;
4020 :latches=EndIdx;
5000 :latches=StartCmd;
5010 :data=8'h01;
5020 :latches=EndCmd;
6000 :latches=StartIdx;
6010 :data=8'he0;
6020 :latches=EndIdx;
6030 :latches=StartCmd;
6040 :data=8'h03;
6050 :latches=EndCmd;
6050 :latches=StartIdx;
6060 :data=8'hb0;
6070 :latches=EndIdx;
6080 :latches=StartCmd;
6090 :data=8'h08;
6100 :latches=EndCmd;
6110 :latches=StartCmd;
6120 :data=8'h80;
6130 :latches=EndCmd;
6140 :latches=StartCmd;
6150 :data=8'h03;
6160 :latches=EndCmd;
6170 :latches=StartCmd;
6180 :data=8'h1f;
6190 :latches=EndCmd;
6200 :latches=StartCmd;
6210 :data=8'h01;
6220 :latches=EndCmd;
6230 :latches=StartCmd;
6240 :data=8'hdf;
6250 :latches=EndCmd;
6260 :latches=StartCmd;
6270 :data=8'h00;
6280 :latches=EndCmd;
6290 :latches=StartIdx;// PIXEL DATA INTERFACE
6300 :data=8'hF0;
6310 :latches=EndIdx;
6320 :latches=StartCmd;
6330 :data=8'h3;
6340 :latches=EndCmd;
6350 :latches=StartIdx;// PIXEL FORMAT
6360 :data=8'h3a;
6370 :latches=EndIdx;
6380 :latches=StartCmd;
6390 :data=8'h50;
6400 :latches=EndCmd;
6410 :latches=StartIdx;//SET PCLK freq=33.26MHz
6420 :data=8'he6;
6430 :latches=EndIdx;
6440 :latches=StartCmd;
6450 :data=8'hff;
6460 :latches=EndCmd;
6470 :latches=StartCmd;
6480 :data=8'hff;
6490 :latches=EndCmd;
6500 :latches=StartCmd;
6510 :data=8'hff;
6520 :latches=EndCmd;
6530 :latches=StartIdx;//SET HBP, HFP
6540 :data=8'hb4;
6550 :latches=EndIdx;
6560 :latches=StartCmd;
6570 :data=8'h20;
6580 :latches=EndCmd;
6590 :latches=StartCmd;
6600 :data=8'haf;
6610 :latches=EndCmd;
6620 :latches=StartCmd;
6630 :data=8'h00;
6640 :latches=EndCmd;
6650 :latches=StartCmd;
6660 :data=8'ha3;
6670 :latches=EndCmd;
6680 :latches=StartCmd;
6690 :data=8'h07;
6700 :latches=EndCmd;
6710 :latches=StartCmd;
6720 :data=8'h00;
6730 :latches=EndCmd;
6740 :latches=StartCmd;
6750 :data=8'h00;
6760 :latches=EndCmd;
6770 :latches=StartCmd;
6780 :data=8'h00;
6790 :latches=EndCmd;
endcase
end
endmodule
And the same code in C is
void TFT_SSD1963_8bit_Set_Index(uint8_t index)
        CS_RESET();
        RD_SET();
        RS_RESET();
        DATA_PORT(index);
        WR_RESET();
        WR_SET();
        CS_SET();
void TFT_SSD1963YT_8bit_Write_Command(uint8_t command)
   CS_RESET();
   RD_SET();
   RS_SET();
   DATA_PORT(command);
   WR_RESET();
   WR_SET();
   CS_SET();
   RST_SET();
   TFT_SSD1963_8bit_Set_Index(0x01);     //Software Reset
     for(i=0;i<0x80000;i++){}
   TFT_SSD1963_8bit_Set_Index(0xe0); //START PLL
   TFT_SSD1963YT_8bit_Write_Command(0x01);
     for(i=0;i<35000;i++){}
   // Wait 100us to let the PLL stable
   TFT_SSD1963_8bit_Set_Index(0xe0);//LOCK PLL
   TFT_SSD1963YT_8bit_Write_Command(0x03);
   TFT_SSD1963_8bit_Set_Index(0xb0); //SET LCD MODE  SET TFT 18Bits MODE
   TFT_SSD1963YT_8bit_Write_Command(0x08); //SET TFT MODE & hsync+Vsync+DEN
   //MODE
   TFT_SSD1963YT_8bit_Write_Command(0x80); //SET TFT MODE & hsync+Vsync+DEN
   //MODE
   TFT_SSD1963YT_8bit_Write_Command(0x03); //SET horizontal size
   //HightByte
   TFT_SSD1963YT_8bit_Write_Command(0x1f);        //SET horizontal size
   //LowByte
   TFT_SSD1963YT_8bit_Write_Command(0x01); //SET vertical size
   //HightByte
   TFT_SSD1963YT_8bit_Write_Command(0xdf); //SET vertical size LowByte
   TFT_SSD1963YT_8bit_Write_Command(0x00); //SET even/odd line RGB seq.=RGB
   TFT_SSD1963_8bit_Set_Index(0xF0);// PIXEL DATA INTERFACE
   TFT_SSD1963YT_8bit_Write_Command(0x3);
   TFT_SSD1963_8bit_Set_Index(0x3A);// PIXEL FORMAT
     TFT_SSD1963YT_8bit_Write_Command(0x50);
   TFT_SSD1963_8bit_Set_Index(0xe6);    //SET PCLK freq=33.26MHz
     TFT_SSD1963YT_8bit_Write_Command(0xFF);//REFRESCO AL MAXIMO
   TFT_SSD1963_8bit_Set_Index(0xb4); //SET HBP, HFP
   TFT_SSD1963YT_8bit_Write_Command(0x20); //SET HSYNC
   TFT_SSD1963YT_8bit_Write_Command(0xaf);
   TFT_SSD1963YT_8bit_Write_Command(0x00); //SET HBP
   TFT_SSD1963YT_8bit_Write_Command(0xa3);
   TFT_SSD1963YT_8bit_Write_Command(0x07);//SET VBP
   TFT_SSD1963YT_8bit_Write_Command(0x00);//SET Hsync pulse start position
   TFT_SSD1963YT_8bit_Write_Command(0x00);//SET Hsync pulse subpixel start
   //position
   TFT_SSD1963_8bit_Set_Index(0xb6);//SET VBP, VFP
   TFT_SSD1963YT_8bit_Write_Command(0x01);//SET Vsync
   TFT_SSD1963YT_8bit_Write_Command(0xef);
   TFT_SSD1963YT_8bit_Write_Command(0x00);//SET VBP
   TFT_SSD1963YT_8bit_Write_Command(0x04);
   TFT_SSD1963YT_8bit_Write_Command(0x01);//SET Vsync pulse
   TFT_SSD1963YT_8bit_Write_Command(0x00);//SET Vsync pulse start position
   TFT_SSD1963YT_8bit_Write_Command(0xff);
This are the gates...
https://alteraforum.com/forum/attachment.php?attachmentid=13596&stc=1
This are the squematic
https://alteraforum.com/forum/attachment.php?attachmentid=13597&stc=1
And this is my result (seems to works good)
https://alteraforum.com/forum/attachment.php?attachmentid=13598&stc=1
What do you think? Anyone have and advice for me? i am in the correct way?
    you are right this are a little part of the code with coments
    input clock ,
    input start  ,                 //not used per now
    input  color_in,      //not used per now
    input  x,                //not used per now
    input  y,               //not used per now
    input  h,                //not used per now
    input  w,                //not used per now
    output reg  data,
    output reg  latches,
    output  finish,                  //not used per now
    output  color_in_next,      //not used per now
    output reg rst
    reg  i_counter=0;     //start i_counter=0
    reg  init = 1'b1;	//variable to start sequencial
    begin
    i_counter<=i_counter+1;		//increment on posedge clock
    //data 8 bits of data bus to external device
    //latches are the clock,cs,write and read this ar params of the external device
    case (i_counter)
    10 :rst=1'b0;			//1 step - reset device
    1000 :rst=1'b1;			//2 step - reset device
    1010 :latches=StartIdx;		//3 step - latches = 0100
    1020 :data=8'h01;               //4 step - send to device = h01
    1030 :latches=EndIdx;		//5 step - latches = 1110	& WAIT of 1000
    2000 :latches=StartIdx;		//3 step - latches = 0100
    2010 :data=8'h01;		//4 step - send to device = h01
    2020 :latches=EndIdx;		//5 step - latches = 1110	& WAIT of 1000
    3000 :latches=StartIdx;		//3 step - latches = 0100
    3010 :data=8'h01;		//4 step - send to device = h01
    3020 :latches=EndIdx;		//5 step - latches = 1110
    4000 :latches=StartIdx;		//3 step - latches = 0100
    4010 :data=8'he0;		//4 step - send to device = he0
    4020 :latches=EndIdx;		//5 step - latches = 1110	& WAIT of 1000
    5000 :latches=StartCmd;		//3 step - latches = 0101
    5010 :data=8'h01;		//4 step - send to device = h01
    5020 :latches=EndCmd;		//5 step - latches = 1111	& WAIT of 1000
    6000 :latches=StartIdx;		//3 step - latches = 0100
    6010 :data=8'he0;		//4 step - send to device = he0
    6020 :latches=EndIdx;		//5 step - latches = 1110
    6030 :latches=StartCmd;		//3 step - latches = 0101
    6040 :data=8'h03;		//4 step - send to device = h03
    6050 :latches=EndCmd;		//5 step - latches = 1111
    One big case statement why?.
    Because i need a sequential and timming excecution on ports
    Best Regards
    Some Points:
    1. Add comments to your code - comments should explain WHY you do something, not WHAT.
    2. Sort the ports out - 1 port per line
    3. One big case statement - why?
    "Are you wanting us to comment on the (poor) coding style", yes i really want a comment or an idea about my poor coding style or another way to doing that.
    Note quite sure what you want? if it works, whats the problem?
    Are you wanting us to comment on the (poor) coding style?
