Sequence Detector Using Shift Registers
I am trying to implement a Sequence Detector that will detect a succession of four 0's or four 1's. This is for a lab using the DE1 Development board. The main problem that I see is that reg_in in the shift register portion of the code is only seeing a 0. This means that only the Zero detecting shift register sees the four 0's. Below is the code, a snapshot of the simulation and how Quartus II is synthesizing the shift register from my code into the circuit. Any help would be appreciated. Thanks!
LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; ENTITY part3 IS PORT ( SW : IN STD_LOGIC_VECTOR( 1 DOWNTO 0 ); KEY : IN STD_LOGIC_VECTOR(0 DOWNTO 0); LEDR : OUT STD_LOGIC_VECTOR( 7 DOWNTO 0 ); LEDG : OUT STD_LOGIC_VECTOR(0 DOWNTO 0)); END ENTITY; ARCHITECTURE Behavior OF part3 IS COMPONENT shft_reg IS --See component description below PORT ( clock, reset_n : IN STD_LOGIC; R : IN STD_LOGIC_VECTOR(3 DOWNTO 0); reg_in : BUFFER STD_LOGIC; reg_out: BUFFER STD_LOGIC_VECTOR(3 DOWNTO 0)); END COMPONENT; SIGNAL Zreg_out, Oreg_out : STD_LOGIC_VECTOR(3 DOWNTO 0); SIGNAL FourZeros, FourOnes : STD_LOGIC; SIGNAL SRg_in : STD_LOGIC; BEGIN SRg_in <= SW(1); Z_SReg : shft_reg PORT MAP (KEY(0), SW(0), "1111", SRg_in, Zreg_out); O_SReg : shft_reg PORT MAP (KEY(0), SW(0), "0000", SRg_in, Oreg_out); FourZeros <= NOT((Zreg_out(0))OR(Zreg_out(1))OR(Zreg_out(2))OR(Zreg_out(3))); FourOnes <= ((Oreg_out(0))AND(Oreg_out(1))AND(Oreg_out(2))AND(Oreg_out(3))); LEDG(0) <= FourZeros OR FourOnes; --The output of the Shift Registers is used in a LEDR(7 DOWNTO 4) <= Zreg_out(3 DOWNTO 0); LEDR(3 DOWNTO 0) <= Oreg_out(3 DOWNTO 0); --four input Negative-OR gate and a four input AND END Behavior; --respectively to detect the four consecutive logic levels library IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; ENTITY shft_reg IS PORT ( clock, reset_n : IN STD_LOGIC; R : IN STD_LOGIC_VECTOR(3 DOWNTO 0); reg_in : BUFFER STD_LOGIC; reg_out: BUFFER STD_LOGIC_VECTOR(3 DOWNTO 0)); END shft_reg; ARCHITECTURE Behavior OF shft_reg IS --Two Shift Registers will be used to detect four SIGNAL regin : STD_LOGIC; --consecutive zeroes or ones SIGNAL sreg : STD_LOGIC_VECTOR (3 DOWNTO 0); --This is done by first resetting them to all ones --(in the case of the zero detector), or all zeroes BEGIN --(in the case of the ones detector) PROCESS (clock, reset_n, R, reg_in) --The output of these Shift Registers is gated above. BEGIN IF (reset_n = '0') THEN sreg <= R; reg_in <= '0'; ELSIF ((clock'EVENT) and (clock = '1')) THEN sreg(3) <= sreg(2); sreg(2) <= sreg(1); sreg(1) <= sreg(0); sreg(0) <= reg_in; END IF; END PROCESS; reg_out <= sreg; END Behavior;2 Replies
Replace the 'buffer' in the port declarations by the appropriate 'in' or or 'out'.
Recompile and then correct the error that will show up. - Altera_Forum
If you have to instantiate shift registers for study then fair enough but a compact way to detect any sequence without using explicit shift register or state machines is to register your input on a proper clock as many times as needed and read all delayed stages.
Using key as clock is not right. to detect "000" or "1111" of input sw:--in a clk process sw_1d <= sw; sw_2d <= sw_1d; sw_3d <= sw_2d; if sw = '0' and sw_1d = '0' and sw_2d = '0' and sw_3d = '0' then zeros <= '1'; elsif sw = '1' and sw_1d = '1' and sw_2d = '1' and sw_3d = '1' then ones <= '1'; else zeros <= '0'; ones <= '0'; end if
