13 years agoSelf reset to FPGA
Hi, I'm integrating an independent FPGA which doesn't have a master CPU associated with it. I need to reset the FPGA right after it enters user mode. Will using Init_done signal Anded with Co...
13 years ago --- Quote Start --- can you point me to the docs where they recommend reset circuitry? if there aren't any async signals to the reset counter, there isn't any recovery/removal to worry about, is there? interesting discussion, thanks :) --- Quote End --- have a look here: http://www.altera.com/support/kdb/solutions/rd06112009_450.html regarding reset,during POR all registers are held in reset of device then it is released. I assume this reset is applied through asynchronous port. remember also external reliable reset is essential in real projects.
