13 years agoSelf reset to FPGA
Hi, I'm integrating an independent FPGA which doesn't have a master CPU associated with it. I need to reset the FPGA right after it enters user mode. Will using Init_done signal Anded with Co...
13 years ago --- Quote Start --- the counter can power up to 0 upon configuration. is there a reason that won't work? --- Quote End --- In prinsiple it should work but altera recommends external reset. I think the reason is that it may fail occasionally due to clock hitting the registers when released from chip reset right after configuration leading to violation of recovery/removal with initial zero changing to unknown value which may freeze the counter or kick it after beyond decision point that generates user reset. A large counter then means less probability of failure.
