13 years agoSelf reset to FPGA
Hi, I'm integrating an independent FPGA which doesn't have a master CPU associated with it. I need to reset the FPGA right after it enters user mode. Will using Init_done signal Anded with Co...
13 years agoHi Boris,
--- Quote Start --- I need to reset the FPGA right after it enters user mode. Will using Init_done signal Anded with Conf_done and looped back to a dedicated reset pin do the job? Am I missing something here? Should delay be added? --- Quote End --- My preference is to route the CONF_DONE signal to the input of a reset supervisor IC. For example, see p95 http://www.ovro.caltech.edu/~dwh/carma_board/gda06rb004_carma_v0.87_dec03.pdf The tri-state buffer is used to isolate CONF_DONE from the other reset sources. Using a reset IC ensures that the reset signal is asserted for a reasonable amount of time. Inside the FPGA, the reset signal is synchronized to each of the different clock domains using the standard asynchronous assert, synchronous deassert scheme seen in various Altera documents (which derive from some Cliff Cummings papers on the subject). Cheers, Dave
