12 years agoSDRAM on DE0-nano board
Hi, I am still not having any success writing and reading from the SDRAM on on the DE0-nano board from the FPGA. I have built a system in qsys which includes a Nios II and SDRAM controller an...
12 years ago --- Quote Start --- I have checked over and over again the pin assignments and qsys settings ... --- Quote End --- The .qar file you sent generates warning messages about unconstrained clocks and paths and TimeQuest fails, so I think that is the root of your problem. Create an .SDC file for your project based on the example I provided. This experience should help you understand that an HDL design consists of (at least); 1. The HDL design files. 2. The device constraints file (device type + pin assignments) 3. The timing constraints file (the .SDC file) Cheers, Dave
