14 years agoSDRAM Controller-Problem
Hi, i build a design in SOPC Builder on Quartus 8.0 (CycloeIII) that looks like this : [CPU]<------->[Half rate bridge]<--------->[SDRAM Controller(not DDR)]. 66MHz ...
14 years agoTry to remove the bridge and let the interconnect to create a hand-shake algorithm to use the SDRAM. I believe 133MHz is just too fast. Try to use 66MHz for the SDRAM chip and 33MHz for the rest of the system before trying that solution I've mentioned before.
