14 years agoSDR to DDR timing constraint conversion
Hi, My design uses classic timing analyser and I have the following constraints for a SDR source synchronous interface. tsu_requirement/th_requirement for input and tco_requirement/min_t...
14 years agoIn general, the problems with Tsu/Th/Tco, like the fact that they basically ignore the difference between rising/falling edges, works in the favor of DDR interfaces, and actually makes it easy. Just use what you have, knowing it will apply to both edges, and you should be all right.
