14 years agoSDR SDRAM controller problem
Hi, I have developed my own SDR SDRAM controller in VHDL to integrate it with the rest of a design inside a Cyclone IV for image processing. By testing the controller I write in the SDRAM 307...
14 years agoHi John,
--- Quote Start --- Problem solved --- Quote End --- Great! --- Quote Start --- The second issue was concerning the clock signal I lead to the SDRAM. It seems it had ringing or some kind of a noise by causing malfunction to the communication between controller and SDRAM. By placing a small capacitor (15pF) between the clock line and the GND signal all errors disappeared. As you realize hardware is custom too. --- Quote End --- Depending on the FPGA, some devices have the option to enable a series resistor on outputs. Check the handbook for your device, or just try enabling a series termination and see if Quartus allows it. Using a series termination will result in a cleaner clock, since it will have faster edge-rates (ideally) without ringing. Using a capacitor is simply slowing down the edge-rates (its an RC filter, where the R is the output impedance of the driver). Cheers, Dave
