14 years agoSDR SDRAM controller problem
Hi, I have developed my own SDR SDRAM controller in VHDL to integrate it with the rest of a design inside a Cyclone IV for image processing. By testing the controller I write in the SDRAM 307...
14 years agoHi John,
Let's say your design must comply with two sets of timing requirements: - SDRAM timing specification itself, namely row precharge time, data latency, refresh period, and so on. This is sort of 'functional' timing and depends uniquely on your hdl code. - FPGA timing; you must make sure all sdram signals generated by fgpa mantain a good synchronization across routing and i/o pins, namely they have no excessive skew or trasmission delays. For this part, you need to carefully constrain your design.
