14 years agoSDR SDRAM controller problem
Hi, I have developed my own SDR SDRAM controller in VHDL to integrate it with the rest of a design inside a Cyclone IV for image processing. By testing the controller I write in the SDRAM 307...
14 years agoNoting that you have written your own SDRAM controller, have you included refresh behavior? If not, it would be best to go back and re-read the SDRAM datasheet.
You will also need to constrain the timing so your design will synthesize properly. If you do not constrain your design, it will most likely not function properly.
