11 years agoSDC constraints for DE Boards Audio Codec WM8731
In examples provided by Terasic there are no constraints for chipset WM8731 for playing/recording audio but when expanding examples I see noise on audio signal recorder from LINEIN and played back to...
11 years agoThis is because you need to relate your inputs and outputs to the main clock not bclk. I can't see the table in the second image - too blurry, can you type out what it is saying? Also please post your main clock rate. There are a few things you need to setup like multicycle constraints and generated clock constraints. Also post how you are creating bclk.
