FTecc's avatar
FTecc
7 years ago
SD-SDI
Hi everyone,
I need to make a sd-sdi receiver.
I tried using ip megacore, but when I created the file the program tells me that I can use it for an hour; I upload the .sof time-limited file to my fpga and immediately the opencore crashes.
I have the 18.1 standard version with university license.
Since I can't find a solution to use ip, even if in trial, I thought to make the program from scratch, but I don't have much information about it.
Can you help me?
Thank you
  • CheepinC_altera's avatar
    CheepinC_altera
    Hi, Just would like to follow up with you if you are able to get in touch with your local sales or FAE to further assist you on the evaluation license? Thank you.
    CheepinC_altera
    Hi, As I understand it, you have some inquiry related to the licensing of the SDI IP core. If I understand it correctly, your existing license seems do not include the SDI II IP license. Just would like to check with you if you are aware of your local sales or FAE contact? You can try to get in touch with them to request for their help for evaluation license. Please let me know if there is any concern. Thank you. Best regards, Chee Pin
