SCFIFO megafunction not working!!
I have created a project by loading SCFIFO megafunction generated vhdl file. When I am simulating in MODELSIM, OUTPUT DATA is not coming even when the Read pulse is enabled. Someone kindly help.
thank you guys..i could figure out!! :)
How can you run a ModelSim simulation without a testbench that generates some input for the FIFO?
This isnt your logic. This is just a wrapper. it does nothing.
With the configuration of the FIFO you chose it will take one clock cycle after a 'rdreq' pulse for the data to show up on the output. Does your simulation code account for this?
Can you post your testbench code so that we can see what you are doing with the FIFO? - Altera_Forum
Can't I simulate the same which is generated.
Thats not your logic - thats the SCFIFO generated from the megawizard.
can you attach the file again.
i have linked it in my first message.
I bet the SCFIFO is working just fine. Its your app code thats not working.
Instead of blaming the SCFIFO thats used in 1000s of projects worldwide without a problem, why not post your interface code and maybe we can help with that.
