GDeXi
6 years agoS10 Device Pin status
MSEL1 and MSEL2 are both external 4.7K resistor pull-downs, but measured as 1.8, look at s10 pcg doc, there is an internal 25K pull-up, according to my understanding should be between 1.8 and ...
- 6 years ago
Hi Guo DeXin,
Perhaps you will need to check your board signal integrity. In S10, pin connection guidelines, it is recommended to route in a way that no aggresor on this. More over, it is a reference resistor pin, is a input pin instead.
Thank You.
YuanLi_S_Intel
6 years agoHi DeXin,
Apologize i dont really understand the question. Are you saying that the output voltage observed with external 2.8K pull down, the voltage is 500mV and this is abnormal?
Thank You
User1574410249703619
6 years agoYes,The pin IO_AUX_RREF and RREF_SDM , the voltage is 500mV and this is abnormal?
