16 years agoRunning NIOS code from SSRAM
Hi, I am trying to run a NIOS code from CY7C1354CV25 SSRAM(32 bits data line) and it is very unstable. My hardware is sharing the address and data bus with a flash device PC48F4400P0TB0E (16 bits ...
15 years agoI made the following changes inside tri_state_bridge_avalon_slave_arbitrator in the NIOS main module. All I did was pipelined the data and write control twice. I had to do this inside the NIOS main module as I was sharing the avalon tri-stare bridge with a FLASH device.
If your SSRAM is not sharing address, data and control pins with any other device (like Flash) you can do the pipeline outside the NIOS main module. I have not tried pipelining the data outside NIOS module, but I guess it should work. Hope this helps!
d1_outgoing_tri_state_bridge_data_r <= d1_outgoing_tri_state_bridge_data_r2 when (sram_s1_in_a_write_cycle_r2 = '1') else outgoing_tri_state_bridge_data;
process (clk, reset_n)
begin
if reset_n = '0' then
d1_outgoing_tri_state_bridge_data <= std_logic_vector'("00000000000000000000000000000000");
elsif clk'event and clk = '1' then
d1_outgoing_tri_state_bridge_data_r1 <= outgoing_tri_state_bridge_data;
d1_outgoing_tri_state_bridge_data_r2 <= d1_outgoing_tri_state_bridge_data_r1;
d1_outgoing_tri_state_bridge_data <= d1_outgoing_tri_state_bridge_data_r;
end if;
end process;
--write cycle delayed by 1, which is an e_register
d1_in_a_write_cycle_r <= d1_in_a_write_cycle_r2 when (sram_s1_in_a_write_cycle_r2 = '1') else time_to_write;
begin
d1_in_a_write_cycle <= std_logic'('0');
sram_s1_in_a_write_cycle_r1 <= sram_s1_in_a_write_cycle;
sram_s1_in_a_write_cycle_r2 <= sram_s1_in_a_write_cycle_r1;
d1_in_a_write_cycle_r1 <= time_to_write;
d1_in_a_write_cycle_r2 <= d1_in_a_write_cycle_r1;
d1_in_a_write_cycle <= d1_in_a_write_cycle_r;
end if;
end process;
Kumaran
