16 years agoRunning NIOS code from SSRAM
Hi, I am trying to run a NIOS code from CY7C1354CV25 SSRAM(32 bits data line) and it is very unstable. My hardware is sharing the address and data bus with a flash device PC48F4400P0TB0E (16 bits ...
16 years ago1 - Basically the idea is to get the clock to the SRAM center aligned with all of the data and control signals. So in my particular case, I was running the SRAM at 100MHz. After calculating delays and everything I decided that I wanted the clock going to the SRAM to be -4.8ns shifted from my regular clock. This translated to the -172.8 degree shift you see in the constraint.
2 - Let me take some time to go back and see how I got to my setup and hold values and I'll get back to you. 3 - You can most certainly constrain it as I have done. 4 - cy7c1380D Have you seen this free training on constraining source-synchronous interfaces? http://www.altera.com/education/training/courses/odsw1160 Jake
