16 years agoRunning NIOS code from SSRAM
Hi, I am trying to run a NIOS code from CY7C1354CV25 SSRAM(32 bits data line) and it is very unstable. My hardware is sharing the address and data bus with a flash device PC48F4400P0TB0E (16 bits ...
16 years agoHi Jake,
Thanks for the code and quick response. 1. I have the SRAM clock connected to a separate port in the PLL as you have mentioned, but I do not know how to determine the phase shift. How did you calculate the phase for sram_clk_int clock? 2. Also for the set_output_delay calculation, I used the formula shown below(it ignore the board delay): set_output_delay -clock<clock source> -min -Th [get ports *] The difference I see between your SDC and mine is the minimum set_output_delay has negative value in mine. Am I missing something? 3. Do we need to use virtual clock for constraining the SRAM pins or can I do the constraint like what you have done? 4. Do you know the part number of the SRAM and flash on your design, so that I can try to decode what exactly you are doing. Thanks Kumaran
