16 years agoRunning NIOS code from SSRAM
Hi, I am trying to run a NIOS code from CY7C1354CV25 SSRAM(32 bits data line) and it is very unstable. My hardware is sharing the address and data bus with a flash device PC48F4400P0TB0E (16 bits ...
16 years agoI appologize I don't have time to thoroughly review all of your post. However, what you ought to consider is creating a seperate clock to drive to the SRAM with a phase offset from the clock which is used to clock your logic.
Below are my constraints from a system which is similar (though not exactly the same) as yours:
create_generated_clock -name {clk_sopc} -source }] }] -add
create_generated_clock -name {clk_reconfig} -source }] -divide_by 2 }] -add
# SRAM clock
create_generated_clock -name {sram_clk_int} -source }] -phase -172.8 }]
create_generated_clock -name {sram_clk} -source }]
# Input Delays
set_input_delay -clock {clk_sopc} -max 9.7
set_input_delay -clock {clk_sopc} -min 5.1
# Output Delays
set_output_delay -clock -reference_pin -max 1.670
set_output_delay -clock -reference_pin -min 0.670
Jake
