PFern11
7 years agoRPD file format question
In AN827 (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an827.pdf) p. 8 in the table about output file types, it says: The .rpd file content has a bit swapped if compar...
JohnT_Altera
7 years agoYes, depending on how you are going to update the flash. If let say you are writing the data into flash in little-endian format then you will need to generate the file in little-endian format. If not then you will need to performed bit swap on your code.
