Routing HPS I2C thru FPGA Not Working
Hopefully you already solved this issue, but anyway some suggestions:
1- You need to enable internal timing arc from HPS to FPGA if you route the EMAC to FPGA I/Os, this is stated also in the CV HPS Handbook (vol 4 : Hps technical reference) where you can see that you need to add the following line into the HPS:
set_global_assignment -name ENABLE_HPS_INTERNAL_TIMING ON
on Old version of Quartus you did need to enable those through an .ini file as you can find on the examples on rocketboards:
https://rocketboards.org/foswiki/view/Projects/CycloneVSGMIIExampleDesign
https://rocketboards.org/foswiki/Projects/CycloneVRGMIIExampleDesign
2- Seen that you're routing those signal through the FPGA you need to provide timing constraint to the I/O as usual (as if you're using an SGMII/RGMII interface depending on what you're using).
Hope it helps.
