Rise/fall time for general purpose outputs in MAX10 devices
- 5 years ago
Hi Valeri,
The report_datasheet creates a datasheet report which summarizes the timing characteristics of the design as a whole. It reports setup (tsu), hold (th), clock-to-output (tco), minimum clock-to-output (mintco), propagation delay (tpd), and minimum propagation delay (mintpd) times. These delays are reported for each clock or port for which they are relevant.
The Timing Analyzer uses advanced I/O timing and board trace model constraints to model I/O buffer delays in your design. If you want to check the 10-90 Rise/90-10 Fall time, you may refer to Input Transition Times / Signal Integrity Metrics.
KhaiY
Hi Valeri,
KhaiY
