13 years agoRing oscillator design issue
Hello i designed a ring oscillator (VHDL) with an up-counter to display its output. The ring oscillators' (80 inverters) output feeds into the clock input to the up-counter and the counter ...
12 years ago --- Quote Start --- This is what I saw in an Altera supplied .vhd file:
component lcell
port (
a_in : in std_logic;
a_out : out std_logic);
end component;
signal ringoscillator : std_logic ;
signal lc1_AOut : std_logic ;
signal lc2_AOut : std_logic ;
-- generate an internal ring oscillator clock running fast
--ringoscillator <= not lcell( not lcell( not lcell( not lcell( not lcell( ringoscillator ) ) ) ) ) ;
-- VHDL needs components
lc1 : lcell port map( not ringoscillator or Reset , lc1_AOut) ; -- the Rest will kick it?
lc2 : lcell port map( not lc1_AOut , lc2_AOut) ;
lc3 : lcell port map( not lc2_AOut , ringoscillator) ;
-- lc3 : lcell port map( not lc2_AOut , lc3_AOut) ;
-- lc4 : lcell port map( not lc3_AOut , lc4_AOut) ;
-- lc5 : lcell port map( not lc4_AOut , ringoscillator) ; I added the Reset signal, not sure that's necessary though. And I understand this is not as pure as the syn_keep attribute, but it works. --- Quote End --- Thanks... well noted
